2009 Freightliner problems
Discussion in 'Freightliner Forum' started by edandedjrtrucking1104, Mar 29, 2015.
  1. edandedjrtrucking1104
    edandedjrtrucking1104 Bobtail Member
    5
    Hi I own a 2009 freightliner century having the check engine red and yellow turning on and of already done it like 6 times in a 250 mile run any one may know what is going on the truck keeps running fine but it worries me any sugestions or answers will be appreciated
  3. Frghter Century 12.7 Detr
    Frghter Century 12.7 Detr Light Load Member
    83
    27
    Mar 6, 2015
    I am well informed about these engines and anybody that owns a Century with a Detroit Engine EGR (I supposed it's a Detroit DD15 2009 model) that check engine comes because the turbo that uses today to burn that soot and regeneration BS makes that turbo run a high like an jet engine. That high pressure creates a signal from the computer diagnosing very high pressure inside the engine. This happens mostly going up on hills and that check engine light comes and goes away as soon that you take the foot off the accelerator and slowly press it back to speed. My Mechanic explained what has to be done but that is something you are going to have to find out your self on the streets. As long that it is not the engine protection that shuts your engine, you should be fine.
  4. edandedjrtrucking1104
    5
    thank you very much the engine is a series 60 515 HP 14.0 thats what the tag on the engine says and it does what you say but it does not shut the engine off
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    The Century should have a display with buttons that tells you stuff like mpg, oil temp, trips info and lots of other things in there. It does have a diagnostic selection that will read back what the codes are if they are active.
    I had a bad coolant level sensor do a bit of that once. If the display happens to say coolant level and you know the level is good, then you could just unplug the level sensor on the coolant tank, you'll get a check engine light stay on, but it won't shut you down,
    But try to catch the codes first, it will read them when it is actually happening if its not in the history section.
  6. Frghter Century 12.7 Detr
    83
    27
    Mar 6, 2015
    Oh 14.0 515, that's a powerful engine! I wrote on the email to pump to 500 but I see it's more then that. Yea follow my recommendations and YOU WILL PUT MONEY IN YOUR BANK ACCOUNT, NOT THE TRUCK PARTS DEALERS AND FUEL COMPANIES!
  7. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,677
    46,250
    Jul 23, 2007
    Midwest
    I moved this to the garage section for you. Many of our members only look in the garage section, so hopefully you will get more help in here.
    25(2)+2 Thanks this.
  8. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    buddy we are ready to help you but unfortunately we are not fortune tellers. If you have fault code post it here.
  9. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    :biggrin_25523: find another mechanic. Honestly...
    Chip S Thanks this.
  10. Landstar412709
    Landstar412709 Bobtail Member
    17
    7
    Apr 8, 2015
    New Marshfield,Ohio
    Unfortunately you may need to take it into freightliner and put it on the diagnostic machine. They usually charge around $150.
