has any replaced the coolant filter housing? mine is leaking at the shut off valve and tring to figure out the best way to fix it
2009 volvo d13 coolant filter housing
Discussion in 'Volvo Forum' started by Offroadjack, Oct 23, 2016.
It's only an o-ring on the shut-off valve. I tried replacing it once. You have to remove the waterpump and get it from the inside, but mine was seized so bad, I thought I'd break the valve off. I ended up just replacing the housing with a good used unit. It wasn't worth the time and effort.
well I took it to Volvo he replaced it on the truck for 280
For 280 it may be they just pulled or unscrewed the valve. The other way im guessing would be way more expensive.
Im asking cuz my shutoff is leaking a bit but i dont want to pull the housing if thats the method...thanks
