2009 volvo D13 Engine Help... PLZ
Discussion in 'Volvo Forum' started by 3zstep, Mar 23, 2016.
  1. 3zstep
    3zstep Bobtail Member
    Oct 21, 2015
    5
    Thanks Received:
    i like the mighty mac bridge, crossed that so many times... i know, i often wonder if its worth the money... i have been looking in to used to swap... i just can't c putting 30 k into a 30K $ truck... thx
  2. 3zstep
    Oct 21, 2015
    5
    Thanks Received:
    NO kidding.... mmm socket... your RIGHT it hurts so bad its almost funny...
    ya, they look just like mine... but yours are running... :( lol
    S M D Thanks this.
  3. S M D
    S M D Road Train Member
    Mar 15, 2012
    2,396
    Thanks Received:
    3,406
    sacramento ca
    Hahah, itll be alright man all negatives have a positive. It sucks but with the 08s and up its expected to not last a million miles. Heck my 08 blew up at 550k sadly but if this happen today god firbid id drive it down the street and watch it burn slowly because of a electrical fire.
    3zstep Thanks this.
  4. flood
    flood Road Train Member
    Dec 25, 2010
    4,167
    Thanks Received:
    4,045
    we had a 08 d13... had a bad injector cup.... dealer had to pull the head to get it out (tyler, tx).... week later we were in the shop again (Portland, or) had to have the overhead done again...... 2 weeks later we were in the shop again (Nashville, tn.) to have the head REPLACED.....! when the 1st shop pulled the head they didn't turk the head right.... a week after that we were in the shop (elpaso, tx.) to get all 6 injectors and cups replaced because Nashville didn't seat them right....
    shops do f--k up things
    KB3MMX and 3zstep Thank this.
  5. flood
    Dec 25, 2010
    4,167
    Thanks Received:
    4,045
    1st finding a backyard mechanic that can do a inframe on a d13 is going to be hard.... Volvo's need special tools.... I have a local shop that can work on a Volvo BUT nothing major.... inframe labor at the evensville dealer is 45 hr's @ $89 = $4005...... parts for a inframe rage from $5,000 (good)$8,000 (better) and $12,00 (best) rod's, main's, line's, pistons, HEAD cam, turbo, cups injestors with a 350k is around $12,000.... I have a est. for my D12 is $17,700 with extras
    77fib77, 3zstep and LumbraX Thank this.
  6. Boromak18
    Boromak18 Light Load Member
    Jan 11, 2018
    62
    Thanks Received:
    11
    Can adjustment screwed the valves?i change injectors 2 months ago and they make the tune up, now after they chack they say the valve war out of adjustment, and cylinder 5 have only 82% compresion. Did they demage the exhaust valve with bad tune up
    KB3MMX Thanks this.
  7. Rob100100
    Rob100100 Light Load Member
    Mar 5, 2016
    206
    Thanks Received:
    122
    Maybe maybe not. After a few months it will be harder to prove. Someone with more knowledge such as Nazria would know more. Sometimes it just happens. Btw the last post was in 2016.
    KB3MMX Thanks this.
  8. benrab
    benrab Medium Load Member
    Apr 5, 2015
    326
    Thanks Received:
    238
    Quebec ,Canada
    On D 13 engine we saw often valve recession problem specificaly on exhaust valves cylinder 5 and 6 on cam side with a high millage engine. The valve and the valve seat start to wear and the valve come too thin and then easy to broke. Adjust the valves periodicaly is the best way to know what’s happen in the engine valve train. Ben
    Newto Trucking, KB3MMX and Rob100100 Thank this.
  9. Rob100100
    Mar 5, 2016
    206
    Thanks Received:
    122
    Thanks for the explanation. I had my injectors/cups replaced in September. Was told that I may not be able to have another valve adjustment as the measurement is that close according to the mechanic. the #1,#2,#3 sealing surfaces were marginal and the #6th sealing surface had failed. Replaced them all. But they did say that the valves and and valve seat were in good condition. Thanks again for the explanation.
    KB3MMX Thanks this.
  10. benrab
    Apr 5, 2015
    326
    Thanks Received:
    238
    Quebec ,Canada
    I forgot to check your head picture first, i'm familar with a failure like this. It's not a drop valve situation it's a broken valve situation.
    A drop valve problem is when the valves keepers (locks) are no more at their proper position for different reasons and the valve fall into the cylinder.
    Wear out situation on valve and seat i think.
    Ben
    KB3MMX Thanks this.
