2009 volvo D13 Engine Help... PLZ
Discussion in 'Volvo Forum' started by 3zstep, Mar 23, 2016.
  1. Boromak18
    Boromak18 Light Load Member
    62
    11
    Jan 11, 2018
    My problem is i change the cylinder head 6 month's ago in July and now they say the problem is with low comprsion on cylinder 5 , how it possible in such short period to get demage.
  3. Boromak18
    62
    11
    Jan 11, 2018
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    How many miles did it have when you replace the cylinder head? And now? How did the liners look while the head was removed?
    How are they coming to the conclusion that it is a head problem?
    Boromak18 and KB3MMX Thank this.
  5. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    One thing happen often the VEB piston internal nut come loose and keep the exhaust valve open and generate a low compression on that cylinder. Ben
  6. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    Possible yes.
    That sucks.
    However.. it's been two months since then and proving that might be hard.
    It's also could be the premature valve guide wear problem that some motors had...
    Socal Xpress Thanks this.
  7. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    With the roker shaft removed it’s a 5 minutes job to inspect all veb piston nuts to know if they started to unscrew by themself. When a veb piston nut unscrew your valve lash will show you too tight in fact the veb piston comes taller than normal and reduce the valve lash. Do you understand me ? Ben
  8. Boromak18
    62
    11
    Jan 11, 2018
    The truck have 810000 miles and head was replaced 30000 milea ago,and they say everything is ok with lower engine, now on 8015000miles they change the injectors becouse truck was shaking and low power, compresion was ok then and after changing injectors shacking stop buth power was still low, boost was going to 22 psi only, i change turbo and actuator and still same problem, then i go beck 6 week later and they make diagnostic and say cylinder 5 have 81% compresion only, probably the head is the problem or piston or liners they dont know.or maybe they do something and dont wont to admit.
  9. Boromak18
    62
    11
    Jan 11, 2018
    On balance test shows
    cylinder 1 is -3
    cylinder 2 is 5
    cylinder 3 is -10
    cylinder 4 is 2
    cylinder 5 is 14
    cylinder 6 is -7
  10. Boromak18
    62
    11
    Jan 11, 2018
    Next week i will take the truck to difrent shop to inspect the truck and i will show them you post to chack that too , thx for you information.
  11. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    If you go to a Volvo dealer ask them to have a look to the bulletin. FSB 213 002 Ben
