2009 volvo vnl670 fault code help please
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mherout, May 3, 2013.
  1. mherout
    mherout Bobtail Member
    10
    Jan 4, 2013
    ILLINOIS
    I have a 2009 Volvo VNL670 with a Cummings engine that is throwing engine faults. I have only had the truck for about a month. I'm hoping that they are some easy fixes. Or at the very least nothing serious.
    The last 8 of the VIN: 9N279060
    #1..
    ENGINE ECU
    Boost pressure
    Value too low
    Active
    Number of events: 3
    MID 128 PID 102 PMI 1
    #2..
    CLIMATE UNIT
    SAE J1708/J1587
    data link
    Communication error
    Inactive
    Number of events: 55
    MID 146 SID 250 PMI 9
    That is what shows on the idiot screen under diagnostics. I clear them and they come back a short time later.
    Any help on this matter would be greatly appreciated. If you need any more info please let me know.
    Thank you in advance!!!
    Michelle
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    the boost pressure is probably a bad sensor climate unit i would guess is loose wire on the data link just check all the connections a little corrosion or loose pin will give u that
  4. mherout
    10
    Jan 4, 2013
    ILLINOIS
    Do you know where I would start looking for the connections/loose pins? I'm not totally stupid I know how to do minor repairs. However a little nudge in the right direction, as far as where to start looking, would be appreciated.
    Thanks Again.
    nasriza Thanks this.
  5. scottscj7
    scottscj7 Bobtail Member
    20
    8
    Mar 3, 2012
    grand rapids,mi
    does this new truck to you have a Qualcomm cable hanging off the back of the cab not attached to anything if the end of the cable gets corrosion in it will cause those problems
  6. mherout
    10
    Jan 4, 2013
    ILLINOIS
    I will have to get up there and check because I do have the Qualcomm cable but no Qualcomm. There is no way of getting rid of corrosion in a wire except for replacing it. As in this case correct?
  7. jameslawton
    257
    65
    May 1, 2013
    Tulsa OK
    U can clean with wd40 and cover with zip lock bag also if they look good would not hut to spay and cove to stop problems later and other wires would be under bunk for rear heater
    mherout Thanks this.
  8. PST
    PST Light Load Member
    125
    53
    Sep 7, 2009
    USA
    Cut the old Qualcomm cable connection and carefully wrap/waterproof each wire so they do not touch anything and reset and retest.
  9. mherout
    10
    Jan 4, 2013
    ILLINOIS
    The company I am leasing too is talking about requiring a Qualcomm. Wouldn't that be a really bad idea too cut the cable or cost me even more to have it installed later??
  10. scottscj7
    20
    8
    Mar 3, 2012
    grand rapids,mi
    I have a friend with 06 that had the same problem as soon as I shook that cable the codes cleared and cleaned connector and wrapped in a ziplock like the other poster said. at his last oil change our mechanic cut the wires to the QUALCOMM where they connect under the dash and that issue will never return
  11. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    I've had the same issue on a few trucks change you're boost sesor all the spot plugs it up and it can't get a valid reading you're fuel is probably down the drain to I think the sensor is less the $100 so it should be an easy and cheap fix.
