We just traded in our old 2003 century for this 2010 Freightliner cascadia with dd15 engine and have 2 active faults that cannot be cleared. Here are the codes:
sam controller
sht lo 249s254 04
sam sa33 spn520908 04
i would appreciate anyone's input as to if these mean that something serious is wrong. We just had a pm done to the tune of $500 and I really can't afford to take it to a Freightliner dealer at this time. Of course we will take it if something is seriously wrong but just trying to find out some info.
thank you
2010 cascadia dd15 active faults problem
Discussion in 'Freightliner Forum' started by Farmers Wife, Nov 6, 2013.
I think its a bulb somewhere...
Farmers Wife Thanks this. -
Thank you for the reply, there is a bulb out on the drivers side courtesy light but haven't been able to figure out how to get the cover off to replace it. Would anyone know how to get the cover off or is there another way to replace the bulb? Thank you
33-520908-4 is the code for the mirror heat fuse not seeing voltage. Check fuse F27 and fuse F7 in the sam cab (behind the glove box). The 249s254 04 is also mirror heat (same code). The reason there are two different codes, is because the sam cab sends out fault codes in two different formats, and the ICU picks up both codes being sent out. No reason to stop and worry. Just check the fuse when you have some down time
To change the driver side bulb, just gently pull lens on the light and you will get access to the light
Thanks Chip, we will check the fuses when we get a chance. The drivers side mirror heat isn't working as we found this out a day ago. And thanks for the info on replacing the lite bulb. I really appreciate the help!
Chip, you were so right! Fuse # F27 wasn't even there! Put fuse in and mirror works and faults were deleted! Thanks again so much for the help!
Plz help I have 2010 freightliner cascadia and I have 4 codes on
Sht 249 s 254 04
Eng Sht hi 128 s 272 03
Sam sa33 spn 521303 04
Eng as00 spn 002630 03
