2010 Cascadia w/ Two Fault Codes
Discussion in 'Freightliner Forum' started by OneTwentyOne, Jan 4, 2017.
  1. OneTwentyOne
    OneTwentyOne Light Load Member
    76
    22
    May 19, 2016
    Hello,
    Can anyone, please, help me with these codes, I believe they are one in the same.
    ENG Sht Hi 128.322.03
    ENG SA00 SPN003250 03
    I've been trying to research to no avail. Any help would be appreciated. I found some oil on my cross member that appears to be dripping from the turbocharger oil supply and drain line from the center housing.
    Your help would be immensely appreciated.
  3. RocketyMan
    RocketyMan Medium Load Member
    554
    339
    Jun 5, 2015
    You need to put in year/model/engine. So like 2010/Cascadia/DD15...something like that so we know if it's a Cummins or a Detroit.
    For fault codes, it's easiest to do it like SA/SPN/FMI...so like 61/3250/3. Usually SPN/FMI is good enough.
    Are you reading these off your cluster? Or do you have DLink and reading them off the fault code tab?
    3250/3 -- Diesel Oxidation Catalyst Outlet Temperature Sensor Circuit Failed High
    If you have the 1-box, check your temp sensor. Should be the one right on the top for the DOC outlet.
    QUALITYTRUCK Thanks this.
