2010 Durastar AC Issue
Discussion in 'International Forum' started by howardleonardjr, Aug 23, 2016.
  1. howardleonardjr
    howardleonardjr Bobtail Member
    Hi guys, trying to diagnose and fix an AC problem on a 2010 International Durastar that is used as a firetruck. Where to start...
    Replaced the cabin filter, blower motor resistor, and 20A buss fuse for the blower motor circuit. Verified that the low side pressure in the system (didn't have the correct gages to check both Low and High) Blower motor circuit gets hot, causing the buss fuse to get hot and trip. Once it cools a little it will reset, but the compressor doesn't come back on unless the ignition is turned off and back on.
    Any help will be greatly appreciated!
  3. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Sounds like a classic case of a failing electric motor. Motor drags, draws more current, trips the breaker. Replace the blower motor.
  4. GreeceMonkey
    GreeceMonkey Bobtail Member
    Change the 20A breaker to a 30A. Rule of thumb is not to have more than 65% load on a circuit, and that system is pushing between 18-21, so more than likely that's the problem. Also check the terminals, they should not be lose, they need to be tight and that could cause some heat. I've also seen the ground lose on the linear power module, and that can cause similar problems.
  5. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Blower motor runs a 30 amp breaker. If the breaker is hot the breaker is either no good, or the terminals it plugs into is loose and causing a bad connection which is causing the heat. This is one problem. If the a/c works after a key cycle, you likely have a problem with the pressure sensor or circuit. Once the system detects a pressure problem, it will shut down the ac until the next key cycle. Check the pressure sensor connector for any corrosion. The high pressure sensor can be changed without evacuating the system.
