2010 freightliner cascadia has problem starting
Discussion in 'Ask An Owner Operator' started by Stevenml95, Oct 11, 2020.
  1. Stevenml95
    Stevenml95 Bobtail Member
    I own a 2010 freightliner cascadia with a dd13 engine, for the past six months the truck has been sitting at the yard and I have just been turning it on once or twice a week and just driving it forward and backwards. Lately it’s been having problems turning on when cold so I have been using starting fluid but once it’s been turned on for 15-20 min I turn it off and turn it right back on and it doesn’t need starting fluid it turns on perfectly. So I was wondering why it doesn’t want to turn on without starting fluid after its been off for a few days? Is it just because it’s not been use on a regular basis or something else?
  3. Spyro2112
    Spyro2112 Medium Load Member
    643
    447
    Mar 17, 2018
  4. Spyro2112
    643
    447
    Mar 17, 2018
    Loses pressure in system
  5. HillbillyDeluxeTruck
    5,985
    30,623
    Mar 3, 2013
    San Antone
    You've not done that truck any favors by doing all that unnecessary starting up and shutting off.
    AModelCat Thanks this.
  6. AModelCat
    165,623
    What?
  7. AModelCat
    165,623
    Problems turning on? What kinds of problems?
    Slow crank speed?
    Long crank times?
    How cold is it outside?
    Throw away that ether can before you wreck the engine.
    feldsforever and Brettj3876 Thank this.
  8. Stevenml95
    It just cranks and it doesn’t turn on, and it’s in the 60s-70s
  9. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    Check valve on fuel return at rear of head is leaking off and you lose prime.
  10. AModelCat
    165,623
    Yeah ether is gonna make that worse if you keep using it. Wrecks the cylinder walls.
  11. Trenton325
    Trenton325 Light Load Member
    102
    154
    Feb 7, 2019
    Starting fluid is bad idea! But you're loosing prime (fuel pressure) most likely a check valve. Is leaking by after sitting.. on pump below primer can take out and clean
