2010 maxforce 13 will not do passive regen.
Discussion in 'International Forum' started by Mr. Truck Fixer, Apr 28, 2013.
  1. Mr. Truck Fixer
    Mr. Truck Fixer Bobtail Member
    46
    13
    Jan 27, 2012
    Ontario
    I was wondering if anyone has had to deal with a maxforce 13 (2010 emmisions) it will not do passive regens while driving down the road or is is sooting up every 250 miles consistantly to the point stationary regens are required. No fault codes, stationary regens with laptop work great nice and hot. We have looked at everything. I have exported the parameters to internaional several times. Is it possible something in the programming during an update could have gone bad disabling passive regens. any ideas would be appreciated.
  3. jackhartjr
    jackhartjr Light Load Member
    158
    128
    Jun 5, 2011
    Hickory, NC
    Totally off subject, but then maybe not. Romney was going to try to reign in the EPA, which is the reason for your woes!
    Jack
  4. Dutch
    Dutch Light Load Member
    194
    58
    Commiefornia
    Check the fuel doser and replace it. The nozzle on them tends to plug and stick, there is also a new gasket for it with a larger hole for the nozzle tip to prevent plugging. If the predoc is damaged it will cause frequent regens, this is most likely due to a failed doser. Make sure the ecm is at the latest cal and there is no exhaust or boost leaks.
    Heavyd and Mr. Truck Fixer Thank this.
  5. Mr. Truck Fixer
    46
    13
    Jan 27, 2012
    Ontario
    Now that you mention boost leak the driver has mentioned the sound of boost leak but we have never been able to track it down. Said it comes and goes.
  6. Dutch
    194
    58
    Commiefornia
    the ETV to head seal tends to leak. They have grey RTV there and blows out, they make a metal gasket now for it.
    Heavyd Thanks this.
  7. Amandeep
    Amandeep Bobtail Member
    So what was wrong with it am having same exact issue
  8. Heavyd
    Heavyd Road Train Member
    7,843
    6,298
    Feb 4, 2009
    Several things will cause no passive regens. We have found fuel delivery pressure slightly too high. There is a grey area where the ECM doesn't like high fuel pressure and will not allow a regen to start, but not high enough to log a code. If your fuel delivery pressure is over 120 psi you will have regen problems. We have seen corrupted body controllers give the engine false regen inhibitors so a regen will not take place. Severely dirty or plugged aftertreatment injectors will cause this. There are many more, but you basically need to plug into it to see. Unfortunately, there is literally nothing a owner/operator can do without diagnostic software to see what is going on.
  9. maxx13
    maxx13 Light Load Member
    135
    15
    Oct 17, 2015
    Im having the same problems, dealer wont check parameters
    Had high and low temp egr coolers replaced, computer upgraded, ati (doser valve) replaced, dpf filter cleaned, still multiple regens. Overheard a "mechanic" say the last time I was at the deal, that nobody had their ASE certification, and he was upset that he couldn't get a raise, need to find a real technician!
  10. Heavyd
    7,843
    6,298
    Feb 4, 2009
    Technician talent is becoming a problem and dealers do not want to pay. Our door rate has increased nearly $30 in the last 5 years and we have not seen any of it. International has cut back the warranty times so bad it is impossible to make a profit doing most warranty work. Dealers avoid it as much as possible.
  11. AModelCat
    166,504
    Do they pay you guys flat rate or by the hour? My last gig was hourly but the regional service manager started imposing all these insane job times on us. Really hard to diagnose an issue in under an hour when you've been on the phone with the manufacturer's tech support department for almost an hour and they basically tell you "good luck, we don't know what we're doing either!"
