2011 670 rear heater core
Discussion in 'Volvo Forum' started by MicksRule, Dec 11, 2013.
  1. MicksRule
    MicksRule Medium Load Member
    412
    354
    Dec 20, 2009
    Apple Valley, CA
    How to replace the rear heater core? Is it really as easy as it looks?I see 2 screws for the cover (already removed) & 1 fastener that holds the pipes to the core. Is there more to it than that? Is there anything else holding the core in the case or keeping the coolant pipes from moving far enough out of the way to lift the core out? I was in the automotive industry for 25 years before driving and HVAC was one of my specialties, so doing the work wouldn't be an issue if I had the truck at home, but on the road may be another issue if it involves removing the case or discharging the A/C system. If it's really that easy, I'll just pick up the parts tomorrow and install them tomorrow night when I stop.
  3. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    may be to late,but you are on track.just don't loose the little clips for the plastic box.good luck.
    MicksRule Thanks this.
  4. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Its pretty easy just slides in and out need to move lines little bit and be careful when sliding bew ine
  5. MicksRule
    412
    354
    Dec 20, 2009
    Apple Valley, CA
    Wasn't to late. I actually left to early the other morning and the dealer wasn't open. I should have time to get it done today. Thanks for the input.
