2011 Cascadia HID headlights not working
Discussion in 'Freightliner Forum' started by darkpony02, Jan 9, 2017.
  1. darkpony02
    darkpony02 Light Load Member
    53
    8
    Dec 1, 2009
    Detroit, Mi
    I bought a set of aftermarket H.I.D lights. I installed them but they wont come on with the headlight switch. I have to turn the headlights on, then disconnect the HID lights, then plug them back in for them to work. I was told the Light Control Module needed to be reprogrammed. I have access to the Freightliner body control program but I was wondering where I could find what needs to be changed. Thank you for your help in advance.
  3. RocketyMan
    RocketyMan Medium Load Member
    554
    337
    Jun 5, 2015
    I think you're confused. Cascadias utilize SAMCHASSIS for the headlight function. If your truck was originally outfitted with incandescent headlights, it will interpret the resistance of such typical bulbs. Since your modifying your truck, the SAMCHASSIS will not know exactly how to interpret you HID setup.
    darkpony02 Thanks this.
  4. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    Reprogramming needed
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Someone on here a while ago said:
    If you shutoff-disconnect the batteries, wait about 15 minutes, re-energize the power, the Sam-module will adapt to the new headlights power requirements.
    Don't know for sure that it works, someone else went from halogens to LED headlight and had a similar issue, this seemed to work for them.
  6. darkpony02
    53
    8
    Dec 1, 2009
    Detroit, Mi
    I'm not familiar with SAM CHASSIS. I'll try cutting power for 15 minutes. Luckily I have a switch that cuts all the power.
  7. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Signal detect Actuation Module. Use to be you flipped on a switch to turn on a light. Now you hit a switch, it tells the SAM computer to turn on light.
    Sounds kind of silly, but it allows for way less wiring under the dash. Basically only two wires go to all of the switches, and two wires handle all of the lighting. Plus all of the other accessories.
    http://www.dtnaecomponents.com/Frei...DateAugust2nd2010AndNewer/SAMWallChart6_0.pdf
    mhyn and QUALITYTRUCK Thank this.
  8. RocketyMan
    554
    337
    Jun 5, 2015
  9. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    sam cab not sam chassis .headlights are hardwired to sam cab
    RocketyMan Thanks this.
  10. RocketyMan
    554
    337
    Jun 5, 2015
    Oh right, my mixup! ..yup yup yup!
