2011 Cascadia problems!!
Discussion in 'Freightliner Forum' started by Elroythekid, May 25, 2011.
  1. Elroythekid
    Elroythekid Road Train Member
    2,626
    5,678
    Sep 9, 2010
    Halifax Nova Scotia
    So I guess the honeymoon is over...My truck has developed several problems. Wipers, engine, cruise, etc. I have posted several videos on you tube and would invite other Cascadia owners to have a look and post any comments you have if you have seen the same problems. I am trying to video all the issues as they come up and post them for discussion.
    Thank you!!
    http://www.youtube.com/user/CWS1963?feature=mhsn
  3. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    It's a freightliner.... Built in Mexico... It's gonna have many many many many issues.
  4. Elroythekid
    2,626
    5,678
    Sep 9, 2010
    Halifax Nova Scotia
    Its actually a Cleveland built truck, a loaded owner op spec truck. I'm hoping its not indicative of how its gonna be for its whole life, if it is, ill go back to an older 07 or earlier Classic, I had way less problems with my 05 Classic. Too bad you can't get the same mpg! Cascadia is awesome on fuel.
  5. Diesel Dave
    9,803
    33,981
    Jan 20, 2010
    Hesperia, Ca.
    You were better off with a VOLVO
  6. Elroythekid
    2,626
    5,678
    Sep 9, 2010
    Halifax Nova Scotia
    Definetly not with the Volvo, Have a friend with a 780, D13, 2008. Its been a nightmare, always on the hook almost has him broke. Minbe hasn't seen the hook and the glitches so far have been very intermittant, that being the problem. I was hoping somebody else mighthave had the same problems and maybe came up with a fix?
  7. Admin
    Admin TTR Forum Owner Staff Member Administrator
    10,252
    15,600
    Apr 6, 2009
    Elroy, if you are more specific about the problems you are having, others might be better able to offer trouble-shooting or recognize the same issues in their rig.
  8. Elroythekid
    2,626
    5,678
    Sep 9, 2010
    Halifax Nova Scotia
    The problems happen when its doing a regen. It will either surge or boost completly dies when cruising along under light loads. When the boost dies the engine rattles and coughs and you can hear the throttle air valve slamming closed, when it slams closed the boost dies, drivability sucks in the first few gears pulling away from a stop it bucks and surges until it gets some boost built up and then takes off and spins right up. You can see the videos on You Tube at this link along with other glitches, wipers and a cruise control glitch. Truck is limited to 105 km hr it will switch to 97km hr and cruise will die and not set, if your bobtail it will pull itself to 110 km hr tho very slowly, then go back to 100, them up to 110 all with your foot to the floor. I'm going to get the limiter turned off, screw the tickets... that may solve that one.
    http://www.youtube.com/user/CWS1963?feature=mhee
  9. Elroythekid
    2,626
    5,678
    Sep 9, 2010
    Halifax Nova Scotia
    So they are telling me the driveability goes away anytime the dd15 is doing a regen. When my truck was new regen was seemless I couldn't tell when it was in regen or not. Now as soon as regen starts it gets noisy, boost dissappears unless your on a hill with your foot on the floor and around town it won't make boost or run smoothly unlees its over 1400 rpm and a load on it. Fuel mileage is also in the crapper. Can anybody with an EPA 07 DD15 tell me if their experience is the same? Or do they even notice their truck doing a regen?
    Thanks
    Colin
  10. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    I've got an '09, and I don't experience any of that - your truck is certainly not running properly. When my truck is operating properly and doing a passive regen, there is not indication that it is happening other than the regen light comes on.
    I have had a problem with the truck concerning regens - I had two intake throttle control valves replaced - its basically a big servo-controlled, butterfly-plate valve. It would jam open, and the system would not regen at all. Eventually the DPF would clog, and the truck would quit running. Valve replacement and a parked regen fixed it.
  11. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    You never said the type of engine that you have in it. I would assume its a Series 60 with DPF. If this is the case, replace the EGR valve on it. My dad had power and fuel economy issues at random and got worse, but there were no CEL's. Eventually, the EGR got bad enough to set a CEL, it was replaced and the truck was back to brand new. There are also sensors that can fail, like temperature sensors for the exhaust, etc. That may cause regeneration issues.
    Replace that EGR valve even if you don't a check engine light, what you will gain in fuel economy and power will justify paying for itself. No guarantees it will fix the problem, but more than likely it will.
