2011 International Prostar ABS module
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 4vmach1, Oct 6, 2017.
  1. 4vmach1
    4vmach1 Light Load Member
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    A 2011 International Prostar with a Cummins ISX CM871 yesterday threw a ABS module fault on the ICU. The TC and triangle light is on. I'm going to check the fuse, but in-case it's the ABS module that needs to be replaced does anyone know where it's located so i can remove it? Thanks!
  3. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    Behind the kick panel in front of the right door and those are wicked expensive. My truck (same specs) will occasionally do the same thing. I disconnect the primary positive battery wire for about 15 minutes, reconnect and it will reboot the module and keep me happy.
    Frank
    Pmarrero88 Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Get it scanned for the actual code. The LCD display is just showing which module is reporting the fault. That does NOT mean the actual ABS ECU has gone bad. All those warning lights are normal with simple ABS faults such as wheel speed sensor or circuit problems.
    Justrucking2 and GrapeApe Thank this.
  5. 4vmach1
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    I'm going to try resetting the battery first. This happen after the doc/dpf/egr were deleted. Maybe a parameter got overlooked.
  6. Sidelined
    Sidelined Light Load Member
    58
    16
    Sep 1, 2011
    northeast, MS
    I recently had mine deleted and get “42 module” sometimes. But after it’s shut off for a while it apparently resets itself. Is this the same issue you’re having?
    4vmach1 Thanks this.
  7. 4vmach1
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    The ABS and TC light stay lite on the icu. Truck has been driven for about 100 miles and batteries were disconnected for an hour, but it hasn't gone away. I'm going to scan it some time next week and see what comes up. I just haven't had a chance to work on it since it's a non-op.
  8. Heavyd
    7,829
    6,280
    Feb 4, 2009
    "Module 42" is the electronic address for the "headway controller" or the front "radar" controller on trucks with Bendix Wingman adaptive cruise control. That module is reporting a fault. If it started after your alterations, then you have a bad tune and likely they inadvertently programmed it out of the engine which you aren't suppose to do.
  9. Sidelined
    58
    16
    Sep 1, 2011
    northeast, MS
    I believe it did it before the delete also, cant remember for sure. It has always corrected itself eventually. Almost like it maybe got wet or something. But now it has been tripped for the last 2 weeks. I need to get rid of that dang front radar crap. Just havent gotten around to it yet.
    Dutchman248 Thanks this.
  10. Heavyd
    7,829
    6,280
    Feb 4, 2009
    Usually the connector right at the front radar has corrosion in it.
  11. Sidelined
    58
    16
    Sep 1, 2011
    northeast, MS
    Is this thing something the original buyer requested? They weren’t standard equipment were they? I want it gone completely if possible.
