2011 Lonestar shifting problems
Discussion in 'International Forum' started by kenny_magnum, May 25, 2014.
  1. kenny_magnum
    kenny_magnum Bobtail Member
    hey folks!,
    I'm stuck at a pit road hauling gravel and my truck wont shift past second gear, I've tried shifting the automatic manually, stopping/restarting even disconnect the battery for a while hoping it would reset something. a code 88 did show up on the dash for a bit but is gone now. its got an Eaton transmission and is a cummins isx need some help!
  3. Dakota1358
    Dakota1358 Medium Load Member
    431
    502
    Jun 15, 2009
    Staunton,Va
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    There is no code 88. 88 in the display is status message that the ECM has finished it's key on pre checks. Usually disconnecting battery power is a good way to reset everything. Let the engine and trans cool down. Try to disconnect the batteries again, and retry. If still a no go, you may have to call the hook.
