2011 Pete 337 Emissions Problems
Discussion in 'Peterbilt Forum' started by CrazyBuckeye, Apr 15, 2014.
  1. CrazyBuckeye
    CrazyBuckeye Bobtail Member
    Acworth, GA
    I bought this truck new and had several modifications done to the chassis and put a custom box on it. I have constantly had problems with getting codes such as "Particulate Outlet Filter Temp" which seems to be the most popular. I have had it in the shop about 30 times and had the DPF Filter cleaned 3 times and replaced once, the sensor replaced along with many times of just having it hooked up to a computer and cleared. Does anyone know what is causing this and what the fix is? I really just want to take it to a field and set it on fire as it is costing me a fortune to maintain and a nervous wreck just waiting for the check engine light to appear in the dash.
  3. digteam6
    digteam6 Bobtail Member
    12
    Mar 5, 2014
    Try ecm programing. Good luck
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    I'm not familiar with the 337's, but it might be helpful if you could drop a hint or two as to what engine you have. Probably a PX of some sort, which I know very little about.
  5. CrazyBuckeye
    Acworth, GA
  6. TOOLS/TIRES
    TOOLS/TIRES Bobtail Member
    4
    did you ever get it fixed I have same problem
  7. Strange77
    Strange77 Light Load Member
    59
    36
    Oct 1, 2011
    Look in to "DPF outlet pressure" reading (in the snap shot for whatever fault is logging) even if it's not throwing a fault for DPF outlet pressure. The SCR catalyst can plug and cause many repeat DPF issues. You don't want to see much of a reading there if it's bad BAD it'll be reading above 10"hg but really anything above 4ish"hg should be investigated.
