2011 Peterbilt 387 not starting
Discussion in 'Trucks [ Eighteen Wheelers ]' started by David387, Sep 5, 2018.
  1. David387
    David387 Bobtail Member
    13
    I’m looking for the starter relay on a 2011 Peterbilt 387.
    I have found 2 fuse box locations.
    1) Behind glovebox
    2) Sleeper compartment inside passenger side access door.
    I do not have a fuse box on firewall on passenger side or driver side.
    I do not have a fuse box under dash by where a clutch pedal would be. (I have an automatic)
    Any ideas?
  3. Check and see if it's really in park. The system is very pickie when it comes to that position. Another option is disconnecting all batteries to let system reset. Then try again after reconnecting batteries.
  4. Goodysnap
    Goodysnap Road Train Member
    3,782
    9,223
    Jul 12, 2017
    Sure it's not 587? VIN please
  5. David387
    13
    1XP7D49X7BD125923
  6. David387
    13
    It’s in Park. Did a rest disconnecting all batteries as you suggested and no go.
  7. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Does it crank? Or doesn’t do anything when you turn the key?
  8. David387
    13
    Just found out from a dealer the starter relay may be behind the instrument cluster. Supposedly because it’s an automatic it doesn’t have the fuse box under the hood. Im going to check that now
  9. David387
    13
    Nothing. It clicks through the starting cycle. Instruments light up, Gauges sweep etc but nothing from the starter
  10. Goodysnap
    3,782
    9,223
    Jul 12, 2017
    I have never seen a 387 without a chassis load center RH side under hood right below the air cleaner. Not saying your wrong. Just never seen it. I can look into VIN specific schematics tomorrow if needed.
  11. David387
    13
    I would appreciate that
