2011 ProStar Air Brake issue
Discussion in 'International Forum' started by DirtyDog13, Jun 6, 2019.
  1. DirtyDog13
    DirtyDog13 Bobtail Member
    12
    5
    May 8, 2018
    I have a 2011 Prostar that is leaking air thru the trailer service line causing the trailer brakes to drag while going down the road. The air leak only occurs when the trailer air supply is engeged(the red button is pushed in). I have isolated the issue to the tractor, the tractor bake chambers have been checked, replaced the red/yellow valve in the dash, and replaced the relay valve that sits under the fifth wheel. Any suggestions would be appreciated!
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Tractor protection valve is where the two cross through the same valve.
    Icyz Thanks this.
  4. DirtyDog13
    12
    5
    May 8, 2018
  5. DirtyDog13
    12
    5
    May 8, 2018
    Thanks Heavy
    Heavyd Thanks this.
  6. Tserra1
    Tserra1 Bobtail Member
    I have a same issues in my truck.how you repair your truck
  7. DirtyDog13
    12
    5
    May 8, 2018
    There is an air relay valve that sits directly below the driver under the cab. Dealer told me it was the Tractor Protection Valve. It is just a standard relay valve, but replacing it solved my problem .
    Icyz and Tserra1 Thank this.
  8. Tserra1
    thank you, you were absolutely right after having lost two days of work thanks to your message my truck is back, THANKS FOR THE HELP
  9. Icyz
    Icyz Bobtail Member
    4
    4
    Dec 15, 2020
    I’m having the same issue now. Will try the above fix tomorrow, crossing my fingers it works.
