2011 volvo d13 engine problem
Discussion in 'Volvo Forum' started by mike23, Feb 22, 2014.
  1. carveer
    carveer Bobtail Member
    8
    Apr 12, 2014
    Chicago,IL
    i have the same problem with my volvo 06 d12 365hp,when im going uphill empty or loaded,rmp starts to fluctuate at 1300 to 1400 ,i changed 3 injectors and nothing...
  3. Bosna
    Bosna Bobtail Member
    Jun 21, 2015
    long story, but I think I know what the problem is.. change the gas pedal and the sensor on pedal it coast around $650 in Volvo services...
  4. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Dealers don't know the problem. They replace parts until the problem is fixed
    Could be the fuel filter the wrong ones they allow too many contaminants to flow through injectors and will eventually mess them up so in the near future if you have injector issues try changing the fuel filter.
    Also the fluctuating Rpms could be from the dpf filter, if yu haven't gotten it cooked you should
  5. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    I recommand you to take time to drove the truck by yourself with a qualified technician with the proper tool already hooked to the truck and road test up to the problem(condition) occur to make the technician know exactly what they should looking for.
    Ben
  6. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    If your road speed is steady but the RPM is fluctuating, the clutch is toast and slipping.
    Most likely won't have codes and will lack pulling power.
  7. Byan
    Byan Bobtail Member
    Aug 17, 2017
    Did you found the problem because I have the same issue with my 2011 d13 500000 mile
  8. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    Could be the turbo actuator, the symptoms on mine was a shortly non responsive acceleration pedal while driving, kind of turbo-lag, but got worst after awhile, i was towed once for this issue, but if i remember was showing turbo codes. In 10 years , 1.8 mil miles i replaces the actuator 2 or 3 times in my D13/08 with this problem, and once the whole turbo/actuator assembly, but turbo was not gone. The actuator was about 900$, not a big job you can do it yourself, i saw it at Auto-Zone also. Another problem i had lossing power without codes, and i wasted lots of time in shops throwing new parts, was bad EGR valve. Well, i'm not sure any of this is your isue.
  9. Chacho2323
    Chacho2323 Bobtail Member
    Sep 23, 2017
    I have the same problem in a 2012 d13 I lost 10% of power I spending 5k so far, now I loosing 60% of power after the last repair, they change my clutch and they bust my speed sensor
  10. Duransav1
    Duransav1 Bobtail Member
    7
    Mar 17, 2018
    did anyone ever find the problem?
  11. Duransav1
    7
    Mar 17, 2018
    I have a 2011 volvo d13 and everytime I go uphill I get power loss as well as rpm fluctuating and vibrating at the same time. It mostly happens when its on 8th 9th and 10th gear. Did anyone get their truck fixed and what was the problem. thanks
