2011 volvo d13 engine problem
Discussion in 'Volvo Forum' started by mike23, Feb 22, 2014.
  1. monsterfacetrucking
    monsterfacetrucking Bobtail Member
    4
    Jul 31, 2018
    Hey, I am having the same problem!!! Violent shaking in 8th gear around 11 to 12 thousand RPM, loss of power and bogging down. Have you figured out what your problem was. Also, the issues get worse when I am pulling a load.
  2. monsterfacetrucking
    4
    Jul 31, 2018
    Hey, have you figured out what your truck problem was? My 2012 D13 is having the same issues, violent shaking in 8th gear around 11 or 12 thousand RPM, bogging down, symptoms worse with a heavy load. No check engine light, nobody can figure this out. I am a new owner/operator and do not have a lot of money saved up right now!!!
  3. Rajatoor
    Rajatoor Bobtail Member
    15
    6
    Mar 19, 2019
    Hi, do you find the problem, what they fixed plz post that. Thank you
  4. manjit1
    manjit1 Bobtail Member
    4
    Oct 9, 2019
    chicago
    Hi, i had the same issue in my 2013 d13 motor breaking rom and shaking spent lot money no codes. finally found good mechanic and he found one injector was bad he changed only one and problem solved right way.
