2011 workstar thumping noise in intake
Discussion in 'International Forum' started by Woody101, Jun 1, 2017.
  1. Woody101
    Woody101 Bobtail Member
    7
    ive got a 2011 workstar and its making a thumping noise that varies with engine speed. We just replaced the throttle valve as it was stuck. Did a cylinder contribution test and they were all within 2-3 percent. Also did an injector buzz test with no faults no codes in the engine computer after throttle valve replacement.
  3. Woody101
    7
    Also DPF system is clean and the media is intact
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Does the engine run smooth? Any noticeable miss? Try disconnecting the air intake to the air compressor and see if that changes anything.
    Woody101 Thanks this.
  5. Woody101
    7
    The engine has no performance issues no stalling no missing just the thumping in the intake and it varies with rpm. I will look into the air compressor tomorrow and let you know.
  6. Heavyd
    7,829
    6,280
    Feb 4, 2009
    Is this a new sound?
  7. Woody101
    7
    We checked the air compressor today disconnected it from the intake piping and still she thumps. The department wanted to use the vehicle so i didnt get any fiagnosis in today other than that. But im thinking it is going to be a flat lifter or a bent pushrod
  8. Woody101
    7
    But yes the sound is new according to the operator but who knows anyway because with the hood down at idle you dont notice it and while you are driving you cant hear it unless you are looking for it. So i dont know if the noise is actually "new"
  9. Heavyd
    7,829
    6,280
    Feb 4, 2009
    Have to pull the rocker cover when you can and see if there is any excessive lash on any of the rockers.
