2012 5500i International steering issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mixingconcrete, Apr 14, 2019.
  1. mixingconcrete
    mixingconcrete Light Load Member
    99
    40
    Apr 14, 2019
    hello, have a 2012 international 5500i. The trucks steering wheel does not come back to the straight position while driving. For example we can turn the steering wheel to the right and let go of steering wheel and it will do circles and wont even come back a bit. We thought it was the king pins at first but after jacking it up and taking off pitman arms, the wheel turn very easy if we push by hand. So it is not king pins. Any advice?
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I made a few trips north in a star like that, which ever way you pointed that thing was where it went when you turned loose of it. It was bad enough that I had a flat on the right steer, and it didn't even try to pull that direction until after the tire was ruint. I felt it slip a little when I turned into cold foot and looked after I parked, the tire was almost flat with knots bulging all out of it.
    We tried everything, eventually found out that the power steering filter had came apart on the previous owner and went through the system. I heard later that it took a gearbox to fix it, but don't know for sure as I never drove it again.I will say it was freakin dangerous.
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Sticky steering shaft or low caster will also cause this.
    AModelCat and spsauerland Thank this.
  5. mixingconcrete
    99
    40
    Apr 14, 2019
    Forgot to mention, the gearbox was rebuilt by a shop and new steering shaft. I am wondering if it could be the power steering pump itself? They are $800 from international i dont want to risk it for that price
  6. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    The pump itself will not cause the steering to not return to center on it's own while rolling. If the front end is free as you say, have the alignment checked. You should be able to turn the wheels lock to lock with the truck not running and axle up on stands. Not from the steering wheel, but from the tire. Any spring work recently? Shims left out by accident?
  7. AModelCat
    165,060
    Lack of caster can cause the steering not to center correctly but you'd likely have a front end shimmy going down the highway (think wobbly shopping cart caster wheel).
    Its been a while since I studdied up on alignment angles but I believe kingpin inclination plays a role in the steering self-centering. When you turn the steering wheel, the angle of the kingpin actually causes the front axle to lift slightly. This downward force helps to re-center the steering.
