2012 Cascadia Cold water leak help?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by reelheavy, Sep 23, 2020.
  1. reelheavy
    reelheavy Light Load Member
    94
    55
    Mar 15, 2017
    Maryland
    Hey all!!
    I have 2012 Cascadia and since the weather has changed here on the east coast going into the 40s at night my truck has sprung a cold water leak somewhere in the front around the radiator.
    It does not leak while it is running but when I park it and come back in the morning there is a new antifreeze spot on the ground.
    my guess is that it is a hose with a hole that is swelling when the motor is hot and shrinking and leaking as it cools over night. But I do not see any signs of the leak when I go to investigate.
    Has anyone ever had to deal with this issue. Again the leak is a In the area under the radiator. It is a dd15 motor has 640k on it.
  3. mitrucker
    mitrucker Road Train Member
    5,502
    10,407
    Dec 15, 2010
    Lapeer, MI
    Check that pipe at the driver side lower corner of the radiator. Also check around all of the clamps.
    magoo68 and reelheavy Thank this.
  4. Roger.B1240
    Roger.B1240 Bobtail Member
    44
    66
    Jun 29, 2020
    Dallas Tx
    Cooling Systems and Fluids.
    Quick Fix might solve a minor leak.
    Good Luck
  5. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Check all the clamps
  6. Dave_in_AZ
    431,145
    Could be the core is cracking. I have a 2012 and replaced mine last January.
  7. reelheavy
    94
    55
    Mar 15, 2017
    Maryland
    Bingo! Checked the lower radiator hose and it show coolant leaking. The upper and lower clamp were a little loose. Snugged them up and will have a diagnosis of the fix tomorrow once I go out. Will let you all know if that fixed my problem. Safe travels.
    mitrucker Thanks this.
