2012 Freightliner Cascadia - Check Engine and Maintenance Light
Discussion in 'Freightliner Forum' started by Singh115, Jun 28, 2015.
  1. jay510
    jay510 Bobtail Member
    How much you end up paying Singh Sab ?
  3. Singh115
    Singh115 Bobtail Member
    22
    10
    Jun 28, 2015
    It was under warrantee. I didn't pay anything, but just a few months later, ended up having to get a complete onebox change out..
  4. robertom224
    robertom224 Bobtail Member
    5
    Wich one is the doser. Thanks
  5. robertom224
    5
    I have the same issue, and the shop replace the filter and reset it, and done but if keeps coming, I hear the doser is the next thing to check or the sensor, check the wires.....
  6. robertom224
    5
    What is the price on the sensor and where is located... Thanks
  7. Jarrods
    Jarrods Bobtail Member
    28
    7
    Sep 2, 2016
    Check to bake sure your DEF isn't contaminated. There can Also be Def buildup under the doser inside the one box. You are going through Def right? Your metering unit can be plugged as well.
    There are 2 nox sensors, one on top of the one box and one at the one box outlet
  8. 1fixitman
    1fixitman Light Load Member
    68
    14
    Aug 16, 2016
    This Isometric drawing has 7 pictures or Figures. Some are for the one box on a Cascadia EPA10 vehicle. EPA10 should be a DD13 or DD15. It also has Drawings for the two box system for the GHG14 vehicle which I believe is cummins ISX but may include others. There are numbers with the sensor named and arrows with numbers to indicate where each is in the drawing. You have to be familiar enough with your system to pick which figure is right for your vehicle and match your vehicle to the correct figure. I hope this helps. I have been digging into my own DEF and DPF issues and have saved a lot of these documents when I come across them. If it did not upload properly then just send me your email somehow and I can send it to you that way. We can figure out how to help you get the info you need. Like I said I hope this helps. Good day.
  9. Luke123
    Luke123 Bobtail Member
    ECE 061 SPN004364 Nox Conv FEF 01 I have 2013 freightliner truck any idea about this code ?
  10. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
