2012 maxxforce fan issue
Discussion in 'International Forum' started by WMGUY, Jun 21, 2022.
  1. WMGUY
    WMGUY Road Train Member
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    Having a fan issue on my 2012 maxxforce 13, fan runs constantly on one speed. I'm going through the diag procedure and my truck has the epa 07 plug so no fan test is available. Has anyone dealt with this issue before?
    Update I applied 12 volts to pin 3 and ground to pin 1. Fan does not turn off. Resistance between pin 1 and 3 is 9.6 ohms which is within spec.
    That leads me to believe the fan clutch is bad. Any insight?
    Thanks Alec
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,050
    2,269
    Dec 15, 2021
    Does the fan spin free when the engine is off?
    Turn the key on,don't start the engine,see if the fan will turn.
  4. WMGUY
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    Yes it spins in both cases
  5. bonder45
    bonder45 Road Train Member
    1,803
    5,453
    Oct 2, 2011
    Williston, ND
    Your fan is pooched.
    On my MX13 I had to get it replaced, I was short on cash so I just put the same stock fan back in for $2k. ( the bearing goes on it and make it constantly run )
    They have aftermarket kits to put a 2 speed fan in which is 100% more reliable.
    The current fan is a variable fan.
  6. WMGUY
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    Thats what I was thinking but hoping not. Lol
    Thanks for the reply
  7. bonder45
    1,803
    5,453
    Oct 2, 2011
    Williston, ND
  8. Carreras
    Carreras Bobtail Member
    6
    4
    Apr 22, 2016
    If you have a scan tool, let me know what your fan speed rpm is reading at idle.
  9. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    Fan is likely no good. Another check is pins 2 to 5 and spec is 2.5k to 4k ohms. If not, fan has failed.
    QUALITYTRUCK Thanks this.
