Ok, here goes nothing... I pulled the dome light fuse, nothing, I disconnected the negative battery wires... nothing... I'm at a loss here...
Here's the issue: When I opened my drivers door this morning, all the dome lights that usually turn on when I open my door turned on, then went to a very dim state, not quite off, then bright again, then dim, etc... They are flashing at a rate of about 4 flashes per second, VERY distracting, and if it was just the overhead lights I would just pull the bulbs til I could get it to a shop, but it's overhead, floor light under my ash tray, and the lights in the bottom of the doors... By the way, when I say I pulled the fuse and disconnected negative battery wires, the lights did not even stop flashing, they kept going... I'm incredibly confused. It's a company truck but I REALLY don't want to call Premier Care over this one, but it's going to effect me driving safely because it's VERY distracting, even in the daylight
2012 Pete 386 Dome Light issue
Discussion in 'Peterbilt Forum' started by mistairs875, Aug 2, 2014.
Had the exact same thing happen on a '10 Cascadia when it was 6 mos old. When you said you disco the neg and nothing happened,,I hope you meant the light went out but the problem returned. We had a master battery switch, and turned it off for 30 minutes,, (25 wouldn't do it lol. ) it was like a huge reset. Freightliner says computer or connector issue...it did this 3 times in the next week,,usually after fueling,,,then never did it again.....
We did spend an hour making sure every connector was seated and not loose,,,all it takes is one poor ground.....good luck,,, -
Nope, like I said, when I disconnected the neg battery wires lights DID NOT stop flashing...
Issue was found, short somewhere, was able to pull out door light fuse and the flashing stopped, now I have no lights when I open door, but probably the switch has a bad connection, if anyone is interested I will post when I find the permanent fix as opposed to just one that I can drive down the road with
I'm having the same problem with my 2010 387 I'm hoping it's just the switch cuz I can open the door while driving and close it and it goes away for about 10 seconds then dome lights come back on along with parking brake buzzer
Had this exact problem. Only thing I found. Left front running light was out. Replaced it and within an hour, dome lights stopped flashing. Problem curred.
18 wheels of fury Thanks this. -
that's weird I have a 2012 Pete and just two days ago my dome lights started flickering so I removed the fuse then I had a taillight that was out so after I put a new bulb in I put the fuse back in and it's good
I'm parked for the night trying to figure it out... been a long day though. Now my interior entry lights are on and the dash is showing my drivers side door is open but it's really closed.
