2012 Peterbilt Cummins ISX oil issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Peterbilt007, Jan 21, 2018.
  1. Peterbilt007
    Peterbilt007 Bobtail Member
    4
    Can someone please tell me if this looks familiar and what it could be.
  3. Dave_in_AZ
    429,906
    Is there oil in the coolant?
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Oil is pretty high up on that intake pipe from your filters. I would say something got spilled on the pipe and it seeped down. When turbos pass oil, its usually on the outlet pipe, and that pipe looks dry to me. Air is usually under a vacuum on that intake pipe, so it is unlikely oil is coming from the inlet of the turbo. I would remove that intake pipe and check the turbo inlet to be safe, but I think that stain came from something else.
  5. Goodysnap
    Goodysnap Road Train Member
    3,781
    9,222
    Jul 12, 2017
    I agree with Heavy. Clean it off and see if it returns. Nothing to get excited about.
  6. Peterbilt007
    4
    The dripping just started today, yesterday that area was dry, and it seems like it’s coming out of the intake pipe of the air filter but the air filter is clean inside.
  7. jake744
    jake744 Light Load Member
    126
    138
    Dec 27, 2017
    Pull the intake pipe off the turbo and make sure oil isn't coming out the cold side of your turbo.
  8. Peterbilt007
    4
    I will do that once I get back to the truck, would a forse regen cause something like this?
