2012 ProStar+ Heater Does Not Work While In Motion
Discussion in 'International Forum' started by Arkevius, Oct 25, 2013.
  1. Arkevius
    Arkevius Bobtail Member
    Hello al! I'm now having a new problem (go figure) with my truck.
    While idle, the cab and sleeper heater works great. However, once the truck starts to move, the can heater gets cold like it was switched to AC Max, but the sleeper heater still works as it should.
    The only way I can get the can heater to work again is by coming to a complete stop, shutting off the truck, waiting a few seconds, and then turning it back on. Heater works fine again until I start to move.
    What's causing this? Something I can fix myself, or is this a mechanic-fixable type of thing?
    Thanks for your help!
  3. Wolfyinc
    Wolfyinc Road Train Member
    2,888
    969
    Apr 21, 2013
    Salem, or
    strange I normally hear this problem with AC and not heater, have you tried playing with the "recirculate"?
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    The only thing you can do is make sure any coolant taps between the engine and cab are fully open. Other than that, the temp blend door is actuated by a little motor that is commanded from the HVAC controls so electrical diagnostics would be needed. The truck moving could be shaking loose some wiring or causing some wiring to short out. The blend door has to be cycling to go from hot to cold like that, unless there is a coolant flow problem from a partially closed tap.
  5. sydsdriver
    sydsdriver Medium Load Member
    363
    242
    Dec 19, 2009
    In the truck
    I had exactly the same problem, but with the AC, in a 2013 Prostar. Right down to the shutting it off to make it work again. International advised that it needed to have a "recall done". They replaced a sensor, that was supposed to tell the system if it froze up. I think there may have also been an issue with a piece of the wiring harness or a plug. Sounds like there may be a similar sensor of some sort on the heat side.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    See post #4
    http://www.thetruckersreport.com/tr...rum/220500-09-prostar-heater-doesnt-work.html
    What do you mean by can heater? Are you referring to the bunk heater under the mattress which is controlled by the bunk control switches? That should be turned off while you are moving. Someone could have it wired incorrectly as it's suppose to have a safety relay to shut it off while the truck is in motion. These modern trucks have servos and sensors down by the blend door that are computer operated.
    From what I've read it's not something for the home mechanic. It requires the laptop and a trained technician with the proper diagnostic tools. It's a common problem with Prostars and involves some reprogramming. I would seek a dealer and not some general repair shop like a TA.
    HeavyD not only is the blend door is actuated so is the heater hose on these newer trucks. I think the taps (spigots) are a thing of the past. The last one I've seen was on a 2005 model.
  7. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    my 09 t660 has one for the cab and one for the bunk.
    the 09 389 i last drove also had taps. those are the newest trucks i've driven.
    i run the bunk heater when it get's below 30. knocks out the draft on the driver door going down the road.
    going to buy some of that foam unsulation autozone sells to see if i can fix that door draft. when i get back home. anything under 20 degrees and that draft gets down right nippy. not to mention the rest of the cab freezing the inside space.
    montana hit MINUS 20 last year. not looking forward to visiting the dakotas this year. you need the bunk heater in that kind of temps. driving down the highway. the cab alone isn't capable of doing it.
  8. Dieselwrangler
    Dieselwrangler Light Load Member
    128
    92
    Oct 16, 2011
    Edmonton, AB
  9. Heavyd
    7,829
    6,280
    Feb 4, 2009
