2012 T800 AC Problems
Discussion in 'Kenworth Forum' started by Colinyost, Sep 15, 2020.
  1. Colinyost
    Colinyost Bobtail Member
    My 2012 T800 ac will not cool less than 50 degrees. The pressures I have is 100psi on the high side and 30 to 40 on the low side when the system is running. When the compressor comes on the low side drops out causing the compressor to shut off then it builds pressure slowly then does it again. I have replaced the compressor, evaporator, cooler, condenser, expansion valve and dryer. I have recharged the system to the correct amount of refrigerant multiple times with no change. The resting pressures indicate there is not a blockage and the pressures are normal given the outside temps.
  3. reeferwrencher
    reeferwrencher Medium Load Member
    591
    1,523
    Aug 4, 2018
    What's the suction pressure drop to when the clutch cuts out?
  4. Colinyost
    It drops to around 10 psi on the low side.
  5. reeferwrencher
    591
    1,523
    Aug 4, 2018
    If you're sure it's not low on freon you could replace the low pressure cut out switch.
  6. landlord
    landlord Light Load Member
    60
    11
    Jan 14, 2012
    chicago il
    You have to adjust your expansion valve counter clockwise
