2012 t800 blower fan not working
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JohnIC, Jun 1, 2024.
  1. JohnIC
    JohnIC Bobtail Member
    19
    11
    Dec 24, 2023
    Have a range of issues, horn not working, wipers not working and heater/ac blower fan not working. Where do I start diagnosing these issues? Checked fuses and they are good.
  3. 5UG
    5UG Light Load Member
    53
    46
    May 22, 2024
    Check the accessory relay located in the fuse box.
    If not that, look for a bad ground connection. Something probably got loose. . .
    Did it all go out when you hit a bump?
  4. FLHT
    FLHT Road Train Member
    1,447
    2,605
    Aug 2, 2014
  5. JohnIC
    19
    11
    Dec 24, 2023
    I'll check the relays next, but all three is unusual.
    Could be water got in somewhere or bad ground on something. My climate controls aren't even lit up.
    Someone messed up with wiring when bunch of work was done on it and now got these issues. Had transmission (18 speed) and compressor replaced. Shop is clueless where to look
  6. 5UG
    53
    46
    May 22, 2024
    I'm pretty sure those 3 particular items share a circuit- that's why I would check relays and ground. Water can certainly cause trouble, but I'm betting on a relay or faulty ground. I believe your climate controls point us further in this direction.
    Depending on the motor, wiring harnesses would enter the equations with the work you had done, but with what you're describing, I'd be looking at the fuse box for bad connections, checking relays, and looking for a faulty ground.
    I'll be curious to find out what you find;
    Keep us posted.
    Kind regards,
    5UG
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,560
    6,647
    Aug 26, 2014
    Some of those KW's are a little different. Not wrong just different and hard to wrap your head around at first. They did not run power through all the switches. The switches when flipped grounded the wire to the panel. That engaged the relay next to the fuse in the panel and sends power to lights and such.
    Blower switch works on the ground side. Grounds the motor through different resistors for different speeds.
    I was waiting on a T800 guru to answer.
    Thanking like the others that a ground wire was knocked doing the transmission or something. When cutting down a forest do not get blocked by the size of the job. Cut down the first tree. Check each of the failed systems one at a time.
    I doubt it is your problem but there are multiple connectors behind the fuse panel. I thank all power going out has to go through them. Believe you can see some of them with the left and center dash panel rolled back. KIMG0721_01_BURST1000721_COVER.JPG That is what they look like when the panel is off the front of the fire wall.
    Start at the beginning and use the KISS principle. Keep it simple Sam.
    5UG Thanks this.
  8. BoxCarKidd
    4,560
    6,647
    Aug 26, 2014
    Fuses are good but do they have power to them?
  9. JohnIC
    19
    11
    Dec 24, 2023
    No power at the fuse terminals when key is in ON position (but not started). Checked fuses for continuity all check out good. Then measured voltage at the fuse panel terminals (when function (wiper, hvac etc.) switch is on) and no voltage. Checked fuse panel in the engine compartment for visual (didn't measure voltages but replaced all fuses just in case). This panel appears to be mainly for emmisions..
    Went over the truck and don't see any ground loose anywhere. If someone has electrical diagram that would help chasing the supply voltage route. Haven't checked relays yet.. Does power go through fuse first then the relays or relays first then through fuses?
  10. BoxCarKidd
    4,560
    6,647
    Aug 26, 2014
    Will this truck start?
  11. JohnIC
    19
    11
    Dec 24, 2023
    Hvac blower fan doesn't have a relay in the fuse box. My t800 is extended day cab. Is there something else?
