2012 terrastar brake problem
Discussion in 'International Forum' started by Cfipilot, Feb 18, 2020.
  1. Cfipilot
    Cfipilot Bobtail Member
    13
    So have a issue with a newly purchased used truck.
    2012 international terrastar
    Issue- after driving a couple mins and getting on highway, the brakes seems to lock or stick. Then because if the dragging the warn engine displays on the dash and the yellow triangle appears.
    so far replaced rear brake pads, front brake lines, front calibers, front pads.
    No ABS light or other warning lights.
    many pointers on what it could be.
  3. AModelCat
    165,509
    Are you sure its sticking brakes and not an engine de-rate?
  4. Cfipilot
    13
    Smoke coming from the brakes.
    also after it happens, I turn off the truck and back on. Put into drive or reverse, no brake or gas Pedal, truck doesn’t move. After it cools down for 30-40 mins. When I put in drive it moves. Would derate cause that?
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Witch brakes are smoking?
  6. Cfipilot
    13
    The first 2 times it happened it was the front. This last time it was the rear brake.
  7. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    Does it have ESC?
  8. Cfipilot
    13
    I would assume so.
  9. dibstr
    1,308
    932
    Sep 10, 2010
    Just spitballing here but I would have that checked out.
  10. Cfipilot
    13
    Would that apply the brakes and issue no warning light or error codE?
