2012 terrastar brake problem
Discussion in 'International Forum' started by Cfipilot, Feb 18, 2020.
  1. Cfipilot
    Cfipilot Bobtail Member
    13
    They have a Hydro-Vac brake Booster, the international dealer seems to think this was the issue. So might be the next thing i replace. However is there a way to test it?
  3. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
  4. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    First thing is the check what the engine is logging for codes. I don't think it logs codes for being worked too hard. There are codes for the brake pedal being held down too long. If the truck sat for a long time before you bought it, it is possible you just have seized calipers. You already replaced the fronts, if your rears are smoking, I would replace those too.
  5. mcoop
    mcoop Bobtail Member
    I have a 2016 doing the same thing. What was your repair to fix it? I was thinking about putting a hydro boost on it. Already did the calipers and break lines. Sounds like we had the same trouble
  6. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    I’ve seen a few of these rust up badly between the master cylinder and hydro boost, causing the brakes to stick slightly.
  7. Michael212
    Michael212 Bobtail Member
    Did you ever figure out what was causing the brake problem?
  8. Michael212
    Did you find the problem yet??
    Thanks,
    Michael
  9. Flaca6533
    Flaca6533 Bobtail Member
    Hi
    Do you fix the brakes issues
