2012 Western Star charging problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by imbzcul8r, Dec 2, 2013.
  1. imbzcul8r
    imbzcul8r Bobtail Member
    5
    Mar 21, 2010
    bc, canada
    2012 Western Star DD15 Delco alternator, I'm driving in the dark in the morning and the lights suddenly go brighter and heater fan speeds up, I look at the voltmeter
    and its pegged out at 16 volts, it does this for 3-4 seconds then drops back to 14 volts where it usually runs. It does this again about every three minutes, so I head for
    the barn because I'm imagining burning out the ecm or lights etc. I watched the datastar readout and it showed 17.5 volts when it would go into
    hypercharge mode. So I call my local western star dealer and ask if alternator chargeing is controlled by the truck computer, he tells me not that he knows of, so I buy a
    new alternator and put it on. Go down the road about 20 miles and same thing, voltage pegs out for 3 seconds then back to normal. This time it only did it 3-4 times then
    started working normally for the rest of the day. I don't think its an alternator problem. Can anyone tell me whether alternator charge output is controlled by built in
    regulator or does it go through a computer?
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Very weird. Something is creating the excess voltage. Never seen batteries create voltage before. Do you have an apu or anything else like an inverter or something connected to the main power?
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I would get the batts tested to start. Id want to rule that out as a problem. If they are fine, I would disconnect the alternator and run the truck a few miles off only the batts. This confirms weather it is the charging circuit or somewhere else.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    i had a similar problem on a kw it turned out to be a wire from altenator to apu thats used to make sure both arent charging at same time it was grounding out to frame and causing a major spike in charge rate
    imbzcul8r and Cetane+ Thank this.
  6. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    If the alternator looses contact from the battery's, it will think that voltage is low, and start charging to the max. This happens on mechanical diesels when someone turns the key off before they pull the stop. I think you have a connection problem between your alternator and your battery's. The real problem is finding an intermittent issue.
    imbzcul8r Thanks this.
  7. truckman29801
    truckman29801 Medium Load Member
    469
    109
    Mar 10, 2013
    SC
    The voltage regulator is almost like the one on some Dodge trucks, there's one in the computer and some in the alternator, either you have a short somewhere in the truck like said above, or the computer or voltage regulator is telling to overcharge. Did you run thru any water or extreme cold recently? and what model is ALT?
  8. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    You most likely have an issue with your remote sense circuit. Try this. Look for the box on the firewall that says "PNDB" It will have a lit red light. Pop open the two yellow clips and open the cover. Remove the remote sense fuse and idle your truck. See if the issue comes back with the fuse disconnected. If it does, you have either a spread pin or a chaffed wire in that circuit.
  9. imbzcul8r
    5
    Mar 21, 2010
    bc, canada
    Todays update-- and thanks to everyone for the useful suggestions. Had a driver on the truck all day and it never missed a beat. The answer to some of the questions asked- 1--It's a delco remy alternator, but I put a new one on and had the same issue afterwards, so I don't think its the alternator. 2-- the truck does not have an apu or inverter 3--I didn't test the batteries but i did put a hand on each to make sure one wasn't going nuclear, they were all cool and there is no problem with cranking and the voltage is good. 4--Yes it was raining but I'm on Vancouver Island and it seems like it is always raining. I think my next step will be to check and clean all battery connections and check out that remote sensor fuse Chip S mentioned, maybe clean any ground connections I find. One other thing I noticed when it would start an episode I would hear a faint click under the dash almost like a circuit breaker tripping, but the voltmeter never dropped, it would just go to max then return to 14 volts after a few seconds. Will update when I find something.
  10. truckman29801
    469
    109
    Mar 10, 2013
    SC
    Just make sure you fix it, prob a connection or a fault in the computer made it overcharge because a connection problem, when they charge that much they will blow sensors. Hope its fixed
  11. imbzcul8r
    5
    Mar 21, 2010
    bc, canada
    Update 2- Still have intermittent high charge, but have narrowed it a bit. Cleaned all battery connections, load tested the batteries, checked the remote sensor fuse.
    It now appears to go full charge when the heater is on defrost and the cycling of the air conditioner kicks in. Also if I set it to any other vent/heater combo it is fine
    but if I turn the air conditioner on it goes to full tilt charge, so I'm thinking maybe the air conditioner compressor clutch or wiring going to it. I have noticed a click noise when it goes hyper and wonder if that's the a/c circuit breaker resetting, then the big charge until the breaker blows. I'm assuming it has a self resetting breaker.Will post again when I have more info.
