2013 8600 air issue
Discussion in 'International Forum' started by joejffrs, Aug 28, 2019.
  1. joejffrs
    joejffrs Light Load Member
    54
    14
    Jul 24, 2018
    San Diego
    My 2013 Transtar 8600 with MF 11 air compressor cycles way to much. Compressor loads after 4-5 miles on the highway with no brake application. At idle, with or without brakes set, both tanks only drop 15 psi in 30 mins. Only loses air when revved up. Both tanks drop to 50 psi overnight. New compressor, (not rebuilt) and governor were installed 6 months ago but it was losing air before then. New rear chambers last week; no improvement. Have used gallons of soapy water and found just a couple small leaks. Took it to the dealer this week and they only found small leaks that didn’t improve the cycling at all. Waste of time and money. Thanks for any suggestions
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Fan clutch or air control valve which could only leak when the engine is running and stop at key off.
    joejffrs Thanks this.
