2013 cascadia air leak
Discussion in 'Freightliner Forum' started by Firedawg11, Apr 23, 2016.
  1. Firedawg11
    Firedawg11 Bobtail Member
    32
    9
    Feb 13, 2016
    air won't build up past 70 psi when idle and when driving won't build past 100 psi... Can hear air pissing out near engine but can't determine where... Any ideas where to look? Thanks in advance
  3. Instinktz
    Instinktz Bobtail Member
    14
    4
    Apr 3, 2016
    Look by the firewall and check under your air dryer. Check while brakes are released holding thw brakes and not holding the brakes. Could be the compressor hose too. Get someone to help you for a quick minute. Try to get a spray bottle of water and you'll be able to feel leaking air without gloves on
  4. Firedawg11
    32
    9
    Feb 13, 2016
  5. Firedawg11
    32
    9
    Feb 13, 2016
    Copy will check in a few, ever since a heavy load it happened thanks for info
  6. AModelCat
    165,064
    Try and hook shop air to supply tank (avoid going higher than 130 psi), turn key on in truck but leave engine off. Lots of air to find the leak and no engine noise to drone it out.
  7. Firedawg11
    32
    9
    Feb 13, 2016
    Been looking all over and I can't not find the air dryer, been underneath, bulkhead sounds like a leak somewhere in engine but I can't see it or feel it
  8. Firedawg11
    32
    9
    Feb 13, 2016
    Never mind found air dryer but nothing sounds like leak
  9. Instinktz
    14
    4
    Apr 3, 2016
    So you can't hear a leak? If not it maybe your governor.
  10. Firedawg11
    32
    9
    Feb 13, 2016
    Turns out it's the discharge line that had a hole in it, it's tucked away under trucks, mechanics working it right now
    Instinktz Thanks this.
