2013 cascadia check engine lights please help
Discussion in 'Freightliner Forum' started by truckerdadyo, Jul 8, 2013.
  1. Zackm81
    Zackm81 Bobtail Member
    23
    13
    Jan 24, 2017
    Longview TX
    Did you have any problems with the switches lighting up? Also, was your jakes and regen not working? I have that same code and took out the switch box that has your hazards button on it. On the back side there is wiring and the very far right wiring on top(has 3 wires with a white plug),.. unplug it and plug it back it back in. If it clears and all dash switches work then you have a bad toggle switch in the sleeper. Turn your battery switch off for 30 seconds and the code will clear.
    Yeah, i know im 6 years late but info is info right??
    joseph1853 Thanks this.
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Never know. It could help someone else.
  4. Truckers Report Jobs
  5. Sherm117
    Sherm117 Light Load Member
    146
    61
    Nov 15, 2015
    1) Chs 71 spn 524049 fail 31
    2) cab 33 spn 524049 fail 31
    3) eng 0 spn 59.6 fail 13
    4) eng 0 spn 60.2 fail 13
    5) eng 0 spn 60.0 fail 13
    6) eng 0 spn 97.3 fail 13
    Can you please help me with these codes? I guess on my last post I forgot to put the spn before the numbers and you replied, can you please help me out man?
  6. Sherm117
    146
    61
    Nov 15, 2015
    Thanks for your help God bless you man. Smh
  7. Toey84
    Toey84 Bobtail Member
    16
    5
    Dec 30, 2020
    Bakersfield CA
    Thanks guys this code came up on a 2014 Freightliner Cascadia with a Cummins engine and our driver stated his jakes did not work. I will check this out. Again thank you all for your advice and recommendations!!
  8. Toey84
    16
    5
    Dec 30, 2020
    Bakersfield CA
    Chip S if my truck is a Cascadia with a Cummins would I use detroit diagnostic link for the subus switch? Insite is just for the Engine correct?
