2013 Freightliner Cascadia quits going down road
Discussion in 'Freightliner Forum' started by salald, Jun 6, 2018.
  1. salald
    salald Bobtail Member
    2013 Cascadia quits going down the road, gauges cycle 4-5 times, then starts running again, happens as often as every 3-4 minutes. Random things won’t work: tail lights, speedometer, fuel/def gauge.
  3. nikmirbre
    nikmirbre Road Train Member
    5,594
    10,371
    Jul 27, 2011
    High Point NC
    Check your battery connections and the line running from your ecm to the battery
    I had this issue before
  4. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    If you have a heavy key set dangling from the switch it sometimes will mess with that switch.
  5. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    you need new PNDB box. Search PNDB here in this forum.
    salald and QUALITYTRUCK Thank this.
