2013 maxforce 13 low power
Discussion in 'International Forum' started by mwilly, Jan 30, 2019.
  1. kubasj05
    kubasj05 Light Load Member
    148
    57
    Apr 18, 2013
    I wish I could help with that but I just got NED and DLB myself so not familiar with the software yet.
  3. mwilly
    mwilly Bobtail Member
    19
    This morning the boost is 30 to 35 and desired is 45 under hard pull
  4. kubasj05
    148
    57
    Apr 18, 2013
    2791 5 E G R C o p e n l o a d / c i r c u i t Possible causes • E G R C c i r c u i t O P E N • F a i l e d E G R v a l v e
  5. mwilly
    19
    It's got me scratching my head, I been at this for 40 some years and kinda old school, you guys are great thanks
  6. kubasj05
    148
    57
    Apr 18, 2013
    You may have issue with egr stuck open.
    Since your boost is not what ecm want and you have egr communication issues that would indicate egr valve failure. Stuck open egr will cause low boost condition. If you choose to go that route I may suggest few other things to consider since you're going to be so far down there.
    #1. Hot side cooler core replacement with M1M aftermarket cooler
    #2 inspect cold side cooler core
    #3 O2 sensor replacement or cleaning at least.
    #4 Doser injector cleaning/replacing
    #5 At least Inspect but I would replace the crossover pipes from exhaust mainfold to egr valve (both). They're not that expensive and they leak or crack often
  7. mwilly
    19
    Feels like the old days with a 270 under the hood
  8. mwilly
    19
    Again I'm old school, if the egr is stuck open why would you lose boost? Fuel makes boost unless the ecm won't give it the fuel
  9. kubasj05
    148
    57
    Apr 18, 2013
    I know the pain, that's why I suggest all the other things to look after because labor involved is significant and I would hate to go back there again for any of the reasons I stated above.
    Note: Disregard #3 in my previous post, forgot to mention that if you remove O2 sensor it's considered a scrap. You will need to install new one.
  10. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    Just took my MaxxForce in yesterday with an EGR code an it came back needing some new EGR valves.
    I’ll let you know the cost later today when I pick up the truck.
  11. mwilly
    19
    Seems to me the egr valve is constantly opening and closing and you keep your power
