2013 Maxxforce 11 Check engine light with no active codes
Discussion in 'International Forum' started by joejffrs, May 3, 2019.
  1. joejffrs
    joejffrs Light Load Member
    54
    14
    Jul 24, 2018
    San Diego
    On my 2013 Maxxforce 11, I had active code SPN 5548-5 this morning-outside temp was 40 degrees. Couldn’t find the exact FMI but FMI 7 is cold start relay or low voltage/open somewhere. Once I drove a mile or so the active code is gone but the check engine light stays on with no active codes. Reset cluster by pulling the fuse. Would guess I have an electrical gremlin-any ideas on where to start?
    Reason for edit: Added truck year and engine
  3. what engine
    what year truck
    joejffrs Thanks this.
  4. joejffrs
    54
    14
    Jul 24, 2018
    San Diego
    2013 Maxxforce 11.
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Start at your coolant reservoir. A lot of times being below the sensor will throw a code and turn the light on, but once you warm up and the coolant expands or runs over the sensor, the code goes away.
  6. joejffrs
    54
    14
    Jul 24, 2018
    San Diego
    Thanks-I edited the post
    peterbilt_2005 Thanks this.
  7. Any and all info helps other know what you have issues with. even if it seems redundant to type, we cant see what your driving.
    Good luck with your ride.
  8. joejffrs
    54
    14
    Jul 24, 2018
    San Diego
    Makes sense. The coolant level is good, I’ve kept a sharp eye on it since I replaced both EGR coolers a month ago. Stays full now.
    HoneyBadger67 Thanks this.
  9. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    The code status you see depends on the type of code reader you are using. International uses 4 different code states. There is "pending", "previously active", "healing" and "active." Once the code is no longer active it will change state to previously active or healing which some code readers cannot pick up.
  10. joejffrs
    54
    14
    Jul 24, 2018
    San Diego
    Thanks Heavyd-I just used the instrument cluster for this info. Have a mechanic with the Navistar licensed scanner. Sounds like I should let him scan and see what it says
    Heavyd Thanks this.
