2013 maxxforce 13 normal oil pressure range?
Discussion in 'International Forum' started by Kakawhalito, May 14, 2022.
  1. Kakawhalito
    Kakawhalito Bobtail Member
    12
    4
    Jan 19, 2022
    Hi guys I have a 2013 maxxforce 13 prostar I just had the oil changed 2-3000 miles ago and the oil pressure while going down the road at 70mph(1500 rpm) is at 40-43psi at 220°. Is this normal? At idle it idles at 20 psi around 200°. It has 640k miles and I'm using rotella 15w-40 with one gallon of Lucas. Is it safe to drive at 40psi hot? Or should I have it checked out? I have a 2012 prostar with the same engine and it doesn't seem to run that low.
  3. Kakawhalito
    12
    4
    Jan 19, 2022
    @Heavyd I know you get a million tags a day but if you have time to give me some insight it'd be awesome. Thank you in advance to you or anyone else who helps out!
    stuckinthemud Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,841
    6,296
    Feb 4, 2009
    20 at idle isn't bad when hot. I'd like to see the pressure more in the 50-60 psi range at 1500 rpm.
  5. Jhncp
    Jhncp Bobtail Member
    41
    Feb 4, 2020
    That sounds fine to me, mine idles at 20 or less when hot and runs about 40. I think as long as you got 30 working it will be fine. Some diesels are suppose to have only 40 psi max so it's not making more heat at higher psi. Also when my oil was changed one time the pressure dropped and it might have something to do with oil filters. The only way to know a job is done right is to do it yourself. When I changed it myself and did filters it seemed to improve.
  6. maneri1891
    maneri1891 Bobtail Member
    31
    Jun 30, 2019
    What year is your truck, and is it a maxxforce?
    Yousername Thanks this.
  7. bonder45
    bonder45 Road Train Member
    1,803
    5,456
    Oct 2, 2011
    Williston, ND
    I love when you start the truck up it’s at 100 psi….
  8. maneri1891
    31
    Jun 30, 2019
    I just did the fan conversion, and my truck also idles at 20 hot, which it has never done. I'm at 1400 rpms,and it's at 48ish psi. We also did the oil cooler , oil pump, and mains and rods. Maxxforce 13.
    Should I be worried. ?
    Reason I did the conversion is because my fan bearing went out. Before conversion I've never been under 40 psi even at hot idle.
  9. BiggDuke
    BiggDuke Bobtail Member
    4
    Aug 23, 2022
    @Heavyd oil getting into coolant reservoir and coolant blows out of reservoir cap when pulling a load is that a oil cooler issue or a EGR issue please help
  10. Heavyd
    7,841
    6,296
    Feb 4, 2009
    Oil cooler. There is no oil/coolant cross over in the egr system like that in the oil cooler.
    BiggDuke and Flint1 Thank this.
  11. BiggDuke
    4
    Aug 23, 2022
    Getting oil cooler fixed right now at International
    Heavyd Thanks this.
