2013 prostar. Cab control module
Discussion in 'International Forum' started by Unhappy owner, Feb 23, 2017.
  1. Unhappy owner
    Unhappy owner Bobtail Member
    No a/c. First started with no heat in bunk. Possibly no a/c at same time, but never thought to check it in 0 degree temps. Plus I have a bunk heater and didnt need to idle. AC is full, compressor works, everything looks good, just no cold air. Cant I bypass the cab control module?
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    A/C on a prostar is all computer controlled. If the compressor is working, do the lines get nice and cold at the expansion valves? If the air stays hot you might just have a temp blend door problem. If you do a search here, I have posted lots about these to hopefully help you.
