2013 volvo daycab On/off battery switch?
Discussion in 'Volvo Forum' started by Osalamah, Dec 10, 2018.
  1. Osalamah
    Osalamah Bobtail Member
    Hey i have a on/off switch right on the bottom of the driver door by my seat and I want to know exactly what it's for it shows the battery icon but what do I use it for and when do i turn it off or on, thanks it's a 2013 volvo daycab
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Should cut the juice off to everything so when your away from the truck for days at a time you will have juice left to start the truck.
    Tb0n3 Thanks this.
  4. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,654
    Oct 5, 2012
    Earth
    It's not like any battery isolator I've ever seen, but I'd have to agree. It's also good for when you have to work on big juicy wires without causing fires.
  5. Brandt
    Brandt Road Train Member
    4,632
    6,367
    Sep 17, 2012
    Freightliner has one on drives side floor. It cut all the power off. They say even with the key off. One computers is running and looking for when you turn the key on. Then it tells all the computers to turn on. So it always drawing a little power even with key off. So if you leaving truck for 3 or more days they say flip the switch and just all the power off. It probably same idea on Volvo.
  6. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    this is an isolator but they mess up all the time connected to a module on top of your batteries that shuts off and turn everything on .
  7. Osalamah
    Okay thanks for the replies but it's not only a switch up and down you can actually press it like a button and so what do you guys think happens if I push it like a button
  8. Tb0n3
    4,738
    9,654
    Oct 5, 2012
    Earth
    Only one way to find out.
    kemosabi49 Thanks this.
  9. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    It’s a remote master switch. I don’t recommand you to turn it Off during the engine is running because your alternator will lost the battery reference voltage.
  10. Osalamah
    Thanks for the help guys appreciate it.
  11. Liquidforce
    Liquidforce Light Load Member
    273
    287
    Sep 27, 2016
    Savannah GA
    I have five trucks with them. Only one works...
    KB3MMX Thanks this.
