2013 Western 4900 DD16 engine brake issues
Discussion in 'Western Star Forum' started by CrankierOwl6972, Jul 5, 2025.
  1. CrankierOwl6972
    CrankierOwl6972 Bobtail Member
    5
    The engine brake on my log truck is acting up. When the engine is cold it works normally, there is never a high setting cause of the program. Once the engine heats up the medium starts getting weak until it’s non existent, and the low gets really weak and stays weak while the engine is hot. If I’m on a haul rode and keep the engine fan on the medium and low work normally, but once I’m on the highway that trick stops working. We sent it to a mechanic who adjusted the valves, put a whole kit in, and replaced the solenoids, but nothing changed. One of the leading theory’s is at one time the engine got hot enough that we lost some compression between the cylinder wall and the piston. I’m the main driver and I don’t believe I saw the exhaust temperature ever get above 900°F, but other drivers do occasionally drive it for a day or so. Shortly before this happened (about a week or 2) the truck started having power issues, which was going on when the Jake issue started. That ended up being the high pressure fuel pump. This is the first DD engine we have ever had so it’s a learning curve for us.
  3. Big Road Skateboard
    7,911
    46,177
    May 2, 2021
    What oil are you using? Does it improve after an oil change? Oil pressure?
  4. JB7
    JB7 Road Train Member
    1,173
    2,219
    Dec 13, 2022
    Laurel, MD
    Jake brake runs off of oil pressure. Oil is much thicker when cold and thins out when hot. What is your oil pressure when the jake is weak vs when it works ok? What does the oil pressure do when the jake comes on? Might be a bad seal/o-ring in one of the assemblies. Check the engine oil to see if it is thinned out with diesel fuel.
    Hammer166 Thanks this.
  5. CrankierOwl6972
    5
    We are using 10-30 blend. We haven’t changed the oil yet, but we have been thinking about it. I forgot to mention the engine was brand new when we got it from auction, and has extremely low miles. Over a year ago it was deleted. The oil pressure is a bit low at idle by about 5psi, but while running I think it is around 55 to 60 something psi once at temp and a bit higher when cold (I haven’t gotten to drive it in about a month as it was passed around between mechanics, so my memory isn’t the best)
  6. Big Road Skateboard
    7,911
    46,177
    May 2, 2021
    I would start with changing the oil, filter, and possibly viscocity
  7. CrankierOwl6972
    5
    Thanks, we will probably try this first.
  8. CrankierOwl6972
    5
    Sorry it’s been so long. We changed the oil and the pick up tube gasket. Still not working. We are gonna try a wiring harness next.
