2014 780 d13 . loosing power after downshift
Discussion in 'Volvo Forum' started by Eduardo lasserre, Mar 27, 2023.
  1. Eduardo lasserre
    Eduardo lasserre Bobtail Member
    Georgia
    its delete so no codes at all , replace egr, turbo and actuator . check valve and still doing the same. shuth the truck off, start again no problems downshif and loss all the power .
  3. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,236
    Sep 27, 2015
    That seems odd. Does it happen when you manually downshift, or when the trans automatically downshifts? If its all okay so long as you don't downshift manually on your own and let the truck do it, I would do that to get to a shop.
  4. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    This is not a very good descriprion of the problem, does it loose throttle all together or just doesn't want to pull, do you have auto or manual trans for starters and when you say loss of power is it engine doesn't pull or battery power coming off any messages in the dash, even if truck is deleted if you connect to 1.12 ptt it will show codes.
