2014 Cummings ISX15 ECM Reports DPF Soot Level
Discussion in 'Ask An Owner Operator' started by rastaman38, Jul 31, 2017.
  1. rastaman38
    rastaman38 Bobtail Member
    7
    4
    Jul 19, 2017
    IMG_1208.JPG Hello All,
    I'm buying a used truck (2014 ISX15 Cummings Engine) and pull the ECM report and I need to now what the highlighted lines mean. The dealer claim they changed the NOX sensor near the turbo and did a parked regen but the tech forgot to clear the code . This is the 2nd ECM report that they pulled because I asked them to address this issue. Anyone with knowledge in this area please respond. Thank you.
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,770
    Mar 5, 2012
    Ontario Canada
    Dpf has probably never been cleaned/baked
    400,000 miles is about the most cummins recommends for this engine
    The rest of the egr stuff is also likely sooted up really good. Look up rawze website for information on how to maintain these systems, lots of good learning there for the isx engines.
    Also see if turbo and actuator has been replaced, I believe it is about a $6,000 repair, and that is IF you replace it before it breaks and goes through the cac and maybe even into the cylinders .... these turbos are great once you get used to them but they are only good for in the neighborhood of 400,000 miles
    Same goes for def filter, make sure has been changed recently.
    Ironmyke and rastaman38 Thank this.
  4. JL of Indiana
    JL of Indiana Light Load Member
    136
    143
    Jul 14, 2017
    Don't quote me on this but I beleive an acceptable range is 1 - 3 for back pressure.
    Looks like the DPF needs pulled and cleaned. I'd be curious what time frame this report is based on with the 98 regens.
    Engine oil usage is the biggest creator of plugged DPF from my experience with only Cummins engines.
    Check with Cummins and see if the fuel tappet update has been done. I believe it's like ATC175 or something... Metal can start flaking off creating A lot of problems if the update is not done. If the truck has oil usage it's likely due carbon compacted rings. Cummins does sell a special oil to help with this.
    Hope that helps some.
