2014 Freightliner Cascadia DD13 Engine Swap Problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Bluto04, Jul 23, 2021.
  1. Bluto04
    Bluto04 Bobtail Member
    Jul 23, 2021
    2014 Freightliner Cascadia DD13 Engine Swap Problems.
    Engine starts but won't stay running without an override.
    Damaged Original DD13 Engine Serial # 471927S0211556
    2014 Freightliner Cascadia Vin # .....ELFP5206
    Engine Year Manufactured 2013
    Replacement DD13 Engine Serial # 471927S0348234
    2017 Freightliner 114SD Vin# ......8HHK3599
    Engine Year Manufactured 2015
    Used Original wiring hardness and Original ECM with Replacement Engine.
    Is the wiring harness bad or the ECM?
    Do I need the ECM from the replacement engine?
    Hasn't ran long enough to warm up in order to trigger some of the fault codes and that is why I think it is something else besides faulty sensors.
    Deleted Codes and they came right back.
    Currently 7 Engine Faults on Replacement Engine
    SPN: 3510 – Sensor supply voltage 2 FMI: 4 (Voltage Below Normal)
    SPN: 94 – Engine Fuel Delivery Pressure FMI: 4 (Voltage Below Normal)
    SPN: 723 – Engine Speed 2 FMI: 11 (Other Failure Mode)
    SPN: 3563 – Engine Intake Manifold #1 Absolute Pressure FMI: 10 (Abnormal Rate of Change)
    SPN: 5927 – Engine Coolant Pump FMI: 2 (Erratic, Intermittent, or Incorrect)
    SPN: 807 – Dif 2 - ASR Valve FMI: 8 (Abnormal Frequency, Pulse Width, or Period)
    SPN: 3719 – Aftertreatment 1 Diesel Particulate Filter Soot Load Percent FMI: 31
  3. ibcalm19
    ibcalm19 Road Train Member
    1,009
    1,360
    Nov 30, 2015
    Pennsylvania
    I would have to talk freightliner on that one. I'm pretty sure they could tell you where the hiccup would be with the difference of wiring between the two chassis.
    Bluto04 Thanks this.
  4. msh
    msh Bobtail Member
    26
    18
    Jul 18, 2021
    Wooow.
    Check the harness. There must be one or two connectors. Check them. With DL trouble shoot each code. What i think one of connectors are not in place...
  5. Magoo1968
    Magoo1968 Medium Load Member
    356
    857
    Mar 18, 2021
    St Malo mb
    Might need the ecm from the 2014 . Are they both the same emission level?
    msh Thanks this.
  6. Bluto04
    Jul 23, 2021
    We used the EMC and wiring harness form the 2014. They should both be the same emissions level. Before we started the engine swap, I contacted Freightliner and gave them the serial numbers to both engines. They said the engines were the same part numbers and would be compatible.
    Magoo1968 Thanks this.
  • Draft saved Draft deleted
