coolant will disappear and reappear and blow out of cap replaced cap builds up pressure affects my heater does not overheat i also put in a new egr cooler no liquid from exhust or in my oil tested thermostats opening and closing as they should any ideas on how to find my problem?
2014 international prostar maxforce 13 coolant problems
Discussion in 'Ask An Owner Operator' started by david mcd, Jan 16, 2022.
Most likely in the dpf scr system. Blow out when on regen maybe?
Maxxforce. That's the problem. Run away before you get stuck with a boat anchor.
