2014 Kenworth T800 check engine light
Discussion in 'Kenworth Forum' started by mefinc1, Jun 28, 2023.
  1. mefinc1
    mefinc1 Bobtail Member
    7
    I have a 2014 Kenworth T800 with a Paccar MX13 engine. I was told the engine brake was not working so I took it out for a test drive and the engine brake was working fine but I noticed the check engine light come on when I would slow to a stop. The CEL light would go off when I would get back up to speed and then come back on when I parked it. I was not hooked up to any trailer and it did not go into derate. I do not have a scan tool but would like to purchase and affordable one that would work for Paccar, Detroit, and Cummins. Any info is appreciated, TIA.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,028
    2,173
    Dec 15, 2021
    Make sure your coolant is all the way full.
  4. mefinc1
    7
    Coolant level is good and all gauges reading correct. I've noticed that the CEL comes on when I let RPMs drop below 1000 coming to a stop sign. I can sit there and rev the engine to 1500 RPMs and the CEL goes off. If i go back down to 1000 RPMs it comes back on and rev up to 1500 RPMs it goes off. Curious if I have some sort of speed sensor going bad. TIA
  5. North Pole Nightmare
    1,028
    2,173
    Dec 15, 2021
    Halliburton has a bunch of those trucks.When doing crew moves we would automatically top the coolant off.
    If the level was close to the cold add mark the check engine would always come on.We would unplug the sensor sometimes when we could see it was full of coolant,but the check engine light would turn on and off randomly.
  6. Zethull
    Zethull Bobtail Member
    48
    21
    May 26, 2023
    KY
    update?
