2014 paccar MX13 Oil pressure sensor problem
Discussion in 'Peterbilt Forum' started by Jonathansalgado99, Feb 15, 2025.
  1. Jonathansalgado99
    Jonathansalgado99 Bobtail Member
    Feb 15, 2025
    I am running into this problem where my oil pressure sensor is working for a bit then it goes up at 100 PSI and doesn’t go down from there. I changed the oil pressure sensor and the oil temp pressure sensor. and still no help. Any help will kindly be appreciated
  3. Arctic_fox
    4,563
    26,046
    Sep 16, 2016
    Are you sure its actully the sensor and not an issue with the engine itself? If you have swapped the sensors it seems more like a problem in the guts then 2 sets of sensors being wrong.
  4. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    MX13 has an electronically-controlled, variable oil pressure system. When it fails, you get maximum oil pressure, all the time. Mine is doing the same thing and I don’t yet know what component fails and causes it. I have an appointment, 2/28.
  5. Jonathansalgado99
    Feb 15, 2025
    Heard that. Let me know on this or text my number what the appointment diagnosis is i am very interested 239-443-9892 ~Jon
    ducnut Thanks this.
  6. ducnut
    2,683
    8,131
    Dec 31, 2010
    SPI
    I never made it into the dealer, 2/28. This morning, the oil pressure dropped to normal and the wrench light went off. Afterward, the oil pressure bounced up a couple times, then, stayed normal. I can’t explain it other than to say another PACCAR doing PACCAR things.
