2014 Prostar heated mirror problem
Discussion in 'International Forum' started by Benjamin Reed, Mar 17, 2019.
  1. Benjamin Reed
    Benjamin Reed Bobtail Member
    I have a 2014 Prostar and the heated mirrors aren’t working. When I activate the switch the indicator blinks rapidly instead of staying on like it used to. Was working fine when I parked her, came back the next morning and it was doing this. I’ve already checked all the fuses and circuit breakers on the passenger side dashboard and that all looks good. Any ideas on what might be the problem or what to check next?
  3. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    159
    265
    Jun 24, 2017
    Could be the module that controls it. Ive had it happen on my freightshaker.
  4. Benjamin Reed
    Thanks, I’ll have my mechanic replace it and see what that does for us.
  5. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    That is a body controller output. The switch is blinking because either it is detecting a short or open. Most of the problems are in the mirror head itself with either corroded wiring or burnt out heater pads.
  6. Benjamin Reed
    Given the winter we’ve had up here in WI burnt out pads are very likely.
  7. kubasj05
    kubasj05 Light Load Member
    148
    57
    Apr 18, 2013
    I have a same problem exactly the same but I haven't got around to taking mirrors apart due to weather and temperature (northern Illinois). I may try my luck this weekend as we're going to hit 60's
  8. Vicente77777
    Vicente77777 Bobtail Member
    The light on the switch for mirror heat is flashing when I activate the defrost mirror and is flashing and flashing flashing driving me crazy
    the truck is a international prostar 2017
  9. Heavyd
    7,830
    6,282
    Feb 4, 2009
    Flashing means there is circuit problem.
  10. kubasj05
    148
    57
    Apr 18, 2013
    HI HeavyD, been a while. How are you?
  11. Heavyd
    7,830
    6,282
    Feb 4, 2009
    Still plugging away. How are you?
